[v2.05] Spin controls in print layout dialog
… are broken: File » Print... » Layout » Gamma
<!-- // EDIT //
  • Verified for v1.99.6 & v2.03 & v2.05
// EDIT // -->
Re: Spin control for gamma correction in print layout dialog
XnTriq wrote:… is broken: File » Print... » Layout » Gamma
What do you mean exactly, XnTriq? The spinning from 1.0 to 0.2 when pressing "Up" button of the spin control? This wrong spinning applies to all spin controls on that dialog.
Thanks for checking, helmut.
helmut wrote:The spinning from 1.0 to 0.2 when pressing "Up" button of the spin control?
Yes, that's what I'm referring to. When I enter the dialog (fresh install), the value for Gamma is 1.00 (default). Clicking the ^ (Up) button makes the value jump to 0.20, clicking the down button makes it jump to 0.10 :bug:
Expected behavior:
  • Up: 1.00 » 1.10
    Down: 1.00 » 0.90
Same goes for the controls next to Margins and Vertical & Horizontal spacing :bugconfirmed:
Re: [v2.05] Spin controls in print layout dialog
Not fixed in v2.13
