18October2013
As far as I can tell the XvV FilExplorer cannot copy the FULL Path+File.ext ...
Is that the case?
If not, I could/would really use it! ... with a HotKey combo ... of course ...
Maybe XnV could allow HotKeyCombos to function differently ...
depending on if the FilEx was "active" ... or NOT ...
Copy Pathname ... + File.ext
Re: Copy Pathname ... + File.ext
In XnView browser, you can copy the image path + filename with extension using the copy function:
1. Open the XnView browser
2. Select an image
3. Select menu "Edit > Copy" or press "Ctrl + C" or use context menu (right click) "Copy"
4. Paste the clipboard contents to a text editor.
Explanation: When copying an image to the clipboard, XnView will copy the image in various formats to the clipboard: The image data will be copied as graphics and the pathname + filename with extension will be copied as text to the clipboard. When pasting to a text editor, the text format will be used for pasting.
2. Select an image
- Forum Librarian
AEN007 wrote:Maybe XnV could allow HotKeyCombos to function differently ...
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=112178#p112178]Re: What does 'Image Data' (Ctrl + shift+c) is supposed to do ?[/url]) wrote:Keyboard shortcuts / hotkeys in XnView Classic:xnview ([url=http://newsgroup.xnview.com/viewtopic.php?t=11285&p=46525#p46525]Copy and Paste[/url]) wrote:Ok, i'll add a hidden setting in 1.90.3HelpDesk-Junky wrote:Please change the functionality back to your older style, please...
CopyClipboard=0 (filename & image), CopyClipboard=1 (image)
- cmd_Copy = Copy selected file(s) = Ctrl+C
- cmd_Copyimage = Copy image data = Ctrl+Shift+C
- cmd_CopyTo = Copy selected file(s) to folder... = Alt+C
XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#View]View[/url]) wrote:
CopyClipboard
- Changes the data XnView will set in the clipboard when copying an image.
Value: Integer, default value is 0
- 0. Copy only image data.
1. Copy image filename and file object.
2. Copy image data, filename and file object.
A good addition, XnTriq. I completely forgot about this UI-less options that had been added.
AEN007
26October2013
