Help with ICC color profile conversion
drugo
Post by drugo »
Hi
i have lots of photos with Adobe RGB or Prophoto rgb color profile embed , and i would like to process them and save them in sRgb
well in xnconvert i got this action , but i'm not sure that everytime xnconverter reads the color profile
because i watched some photos , converted to sRGB and they look different
to convert adobe rgb and prophoto rgb to sRgb what setting should i use?
in the imput profile there is sRGB by default , does it mean that i have to load a color profiles ,in the imput profile?
or xnconverter can detect the color profile?
thanks
Re: help with color profiles converter
if your image file has no ICC profile data, you must enter an input profile
drugo
Post by drugo »
xnview wrote:if your image file has no ICC profile data, you must enter an input profile
but if there is a icc profile , xnconvert can detect it , right?
yes
