Command Line Parameter Question...
photofan
Post by photofan »
Hello.
Is there a way to start xnconvert with some command line parameters to convert the pictures in a special directory with
a script, which is loaded by default? I need just the command line parameter(s) to start the process. When I start it
with the directory in command line, the pictures are marked and my default script ist loaded. It would be ideal to
start xnconvert with a "run" command to run this script and end the program after it automatically.
Regards
photofan
