PDF-pictures are not importable by the clipboard
jens116
Post by jens116 »
If I copy a picture of an PDF-document into the clipboard and import it into xnview it is damaged (you only see a little white square). The import into other graphic programs is no problem.
Windows 98 SE and XP
Acrobat Reader 6.0
XnView 1.80.1
marsh
Post by marsh »
I cannot recreate problem on Win2K. Perhaps this problem only occurs on Win98?
A workaround…
:) Hello !
- I use "Foxit" PDF Reader; there is no way to select only an image in that reader. So, I copy the page in the Clipboard with Alt+PrintScreen, then I paste its content (import) and crop / save to keep only the image. A workaround not too long, in fact.
- Under Win 98 SE
:mrgreen: VG
Re: PDF-pictures are not importable by the clipboard
jens116 wrote:If I copy a picture of an PDF-document into the clipboard and import it into xnview it is damaged (you only see a little white square). The import into other graphic programs is no problem.
I can't reproduce it.
