0.61: Selection sometimes starts at wrong position
Frankcowperwood
Post by Frankcowperwood »
<Moderator's note: This topic has been split from another topic>
Hello.
I use XnViewMP 0.61. I often cut pictures witр this program. I cut a lot pictures....But there is one little problem during selection a part of picture.... It's difficult to explain but I try...For example I open the first picture in folder where there are 100 another pictures. I select the part of first picture and then click "to cut", then press "Enter" in order to change picture, Then I do the same: "I select the part of picture and then click "to cut", then press "Enter" in order to change picture"...everything is good, but sometimes one problem appear with selection: in order to select a part of picture I need click at picture twice because first click start selection in wrong place.
P.S. I hope I explained clearly. Sorry for my English. It's not my native language. I hope you will solve this problem or maybe you explain me how to solve it.
Thank you
m.Th.
Re: 0.61: Selection sometimes starts at wrong position
Post by m.Th. »
Do you mean that after a crop, next time the selection box isn't in the place where you click?
m. Th.
Frankcowperwood
m.Th. wrote:Do you mean that after a crop, next time the selection box isn't in the place where you click?
yes
