XnView to read Dicom explicit Litle endian TS format?
Endian
Post by Endian »
It seems like XnView is not able to read Dicom files in the explicit litle endian format. It is though able to read the implicit format.
Is there any workaround or do you plan on including the ability to read explicit litle endian Dicom format?
Re: XnView to read Dicom explicit Litle endian TS format?
Endian wrote:It seems like XnView is not able to read Dicom files in the explicit litle endian format. It is though able to read the implicit format.
Could you send me some samples, please?
Endian
Post by Endian »
Email with samples sent.
Endian wrote:Email with samples sent.
on [email protected] (remove -nospam)?
Endian
Post by Endian »
Right - I sent it to your personal emailaddress - resent to the one you stated here.
