Lubuntu13.10-pcmanfm -- xnviewmp as the default appl
quapurna
Post by quapurna »
Halo, XnViewMP developer.
Lubuntu 13.10
PCManFM 1.1.2
From within pcmanfm, I assigned XnViewMP as the default application for png expecting that if I double-clicked the png file, XnViewMP would open displaying the image. However, I got popup message saying "File not found".
To make it work; from pcmanfm, I must manually set the xnviewmp location which is "/usr/sbin/xnview".
It seems that the default file-association feature in pcmanfm uses /usr/bin/ .
I am not sure if it is pcmanfm or xnviewmp problem.
Thanks.
Skulptron
Re: Lubuntu13.10-pcmanfm -- xnviewmp as the default appl
Post by Skulptron »
Thanx quapurna,
your instruction is very useful!
Also, here is another solution:
http://newsgroup.xnview.com/viewtopic.p ... fm#p113682
Lubuntu 13.10
