Selection Ratio droplist in toolbar
spacebug
Post by spacebug »
Is it possible to add a new command in the toolbar menu to have a button with droplist of all Selection Ratio ?
I try by tapping "cmd_Set_SelectionRatio" but it doesn't work.
Same, is it possible to add new commands to swap width & height and to select "same as image" ?
I know there is the shortcuts TAB and D but I prefer button than extra memory extension to store all shortcuts :wink:
In parallel, how I can fix the default selection ratio when I open XnView ?
For me, "Same as image" is more important than "Free".
Best regards.
(XnView v2.05, Windows 8.1)
Re: Selection Ratio droplist in toolbar
spacebug wrote: Is it possible to add a new command in the toolbar menu to have a button with droplist of all Selection Ratio ?
Ok, i'll check
You would like that 'Same as image' is by default?
