I press Ctrl + 5 to give a photograph 5 star rating.
However it never seems to save to Windows' star rating system in Windows Explorer? Why is this and is there a setting I can use or is it just not compatible?
Pressing Ctrl+5
Re: Pressing Ctrl+5
you must enabled option>Metadata>Write rating
