I noticed that some of my images with embedded gps data seemed to be slightly misplaced in the map.
It looks like there are too few decimal places passed to google maps.
For example, if the data is currently passed to GM as 3 decimal places of degrees, then at least 4 decimal places is required to match a typical set of coordinates, and even 5 decimal places for a good reading.
Geolocation precision
Re: Geolocation precision
could you send me sample files?
CameronD
OK, I will pack a couple of images taken in close proximity and screenshots illustrating the difference.
CameronD
As a point of clarification, the apparent rounding is only seen in the embedded GPS tab within xnviewMP.
If I use the tools-> open in google earth or Geohack then the full resolution is used.
Bug confirmed and will be fixed. See issue Issue 151 for current status and details.
