I am trying to export an interlaved RGB raw file with XNConvert.
default export is with separate planes and the format setup option is not selectable.
Anybody can help me ?
regards.
Need help : XNConvert - Raw export
Re: Need help : XNConvert - Raw export
The RAW option are missing, please try with XnView
oxythan
Thank you Pierre,xnview wrote:The RAW option are missing, please try with XnView
It works fine, you save me
Any plan to update XNView raw export setup in the near future ?
Another question, If i directly use nConvert (with an hand written script) , do you know if i can choise raw setup ?
What do you mean?oxythan wrote: Any plan to update XNView raw export setup in the near future ?
[/quote]Another question, If i directly use nConvert (with an hand written script) , do you know if i can choise raw setup ?
you have -corder
