0.61: Drag Photos into GPS Pane
rmtk
Post by rmtk »
When I accidently dragged a photo into the GPS pane, I found the photo replaced the google maps in the pane and I couldn't undo it unless restart the program. I dont't think it should behave like this.
It's a minor bug. Hope a fix in the next version.
Re: 0.61: Drag Photos into GPS Pane
Problem reproduced in v0.84.
:arrow: Reproduced
O.k., thank you, I can also reproduce the problem. Issue 157 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
Confirmed fixed in 0.85 beta 1
