can i add copyright to the image?
drugo
Post by drugo »
hi
can i add copyright to multiple image?
how can i do it?
thanks
Re: can i add copyright to the image?
I think it could be done as follows:
Tools > Batch processing...
On the Transformations tab select Image -- Add Text
In the Parameters space paste the © symbol (copy and paste from this post, for example).
Select the other settings to get the result you want.
Note:
Test using a copy of your images as there may be no Undo function available!
