I mainly use XnView(MP) as fullscreen-viewer for images. Therefore when double-clicking an image in the explorer I always show the image in fullscreen.
While using XnView I got accustomed to the behavior that I can quit XnView from Fullscreen by pressing ESC. However in XnViewMP this only switches back to the windowed view.
Is there an option to change this behavior of XnViewMP to make it directly quit XnView when the user presses ESC in fullscreen mode?
BTW:Even pressing Alt-F4 in fullscreen mode does not quit XnView instead the effect is identical to pressing ESC - the image is shown in windowed mode.
XnViewMP Version 0.61 (Jul 18 2013) (Win7-64)
0.61: Close XnView by pressing ESC in fullscreen mode
rob
rob
Re: Close XnView by pressing ESC in fullscreen mode
I found it.
Settings -> General -> Keyboard/Mouse -> "Pressing ESC once quits XnViewMP"
However there is a bug: Changing it to "Always" does not change anything. It only works correctly when set to "Only in fullscreen".
