Changing hotkey file associations in XnView
DigiDog
Post by DigiDog »
Hi all... I've recently upgraded from Photoshop CS6 to CC and I've uninstalled CS6 from my computer. I've changed the Win7 file associations, but my XnView file associations still refer to CS6. It's the hotkeys I really want to change.
Photoshop CC is on now my menu as Alt+3. I used to use Alt+1 for CS6 - that still exists in XnView. I'd like to delete that one and replace it with CC because I'm used to hitting Alt+1 in the XnView browser to open raw files in Photoshop. Is it possible to delete or edit old associations like this in XnView?
By the way, I'm currently using v2.11 - and loving it! Thanks!
Re: Changing hotkey file associations in XnView
No easy way, but you can edit the xnview.ini
DigiDog
Post by DigiDog »
Wonderful! Thanks Pierre.
