show embedded rating
kweso
Post by kweso »
hey, got a bunch of jpgs from a client which he rated using adobe bridge. but i cant see those ratings in xnViewMP 0.61 (win7 64bit) as thumbnail-overlay (i turned that on and when i do a rating within xnViewMP, it shows the star). but when i open the properties of one of my clients images, i can see his rating under "details". is there any way to control this?
thx vm!
kws
Re: show embedded rating
could you send me a file sample?
kweso
Post by kweso »
sent you a pm, because the photo is copyrighted.
but heres a screenshot:
i opened the properties of 0019_...jpg where you can see the 4*-rating from bridge, which is not represented on the thumbnail (and cannot be filtered or sorted by).
i rated and color-labeled 0030_...jpg in xnViewMP, so you can see that icon-overlay is turned on for all items.
thx and hf,
kws
I have not the problem. Could you try with a clean database?
Perhaps it's related to this bug
