Hello everyone!
I need to do a batch proportional scale of cca. 6600 images - I am converting my gfx between two 16:9 resolutions.
Moreover I need them to keep their original formats (png, jpg) and simply replace the files in their respective directories.
Of all the software XnViewMP was the only one which would work IF there was an option to enter 66.66666% instead of 66%. (1920x1080 down to 1280x720)
Is there any other way how to do this task to get an exact result? I fear doing 200% and then 33% would destroy the files too much?
Thank you,
Jan
Scaling through percents - missing floating point?
Re: Scaling through percents - missing floating point?
Support++
However...
However...
No - IF you work with files with lossless compression. So do not use JPEGs, use PNGs. But I don't know that this suits to your case.Is there any other way how to do this task to get an exact result? I fear doing 200% and then 33% would destroy the files too much?
m. Th.
