Photoshop EPS?
chrishaas
Photoshop EPS?
Post by chrishaas »
As far as I can tell Photoshop's EPS format isn't supported, only the standard Illustrator version. I tested several files here and none of them worked. Can this format be added?
Re: Photoshop EPS?
chrishaas wrote:As far as I can tell Photoshop's EPS format isn't supported, only the standard Illustrator version. I tested several files here and none of them worked. Can this format be added?
There's little we can do in XnView: EPS files are read using Ghostscript AFPL. If you want to view Photoshop EPS files, your request should go to the Ghostscript AFPL forum.
