can i send multiple files to custom button?
drugo
Post by drugo »
Hi
i create a custom button
but when i select many files and click on the xnview icon , xnview send only 1 photo
thanks
Re: can i send multiple files to custom button?
Strange, do you have tried with another program?
drugo
Post by drugo »
xnview wrote:Strange, do you have tried with another program?
yes i have many progrrams , in the browser , and xnview send only 1 photo to the icons
run it under windows 7 64bit
right, sorry, currently only 1 file used, i'll fix it
drugo
Post by drugo »
xnview wrote:right, sorry, currently only 1 file used, i'll fix it
thanks Pierre!
captaincavern
Post by captaincavern »
Hello, since version 2.13, opening an image with AzPainter2 from an XnView toolbar button doesn't work anymore. This program only supports opening an image at once and fails to open anyhing if multiple files are sent to it. It seems the 2.13 fix messes with it even though I don't try to open multiple images in it from xnView. It's japanese software but there is an english translated version here: http://www.mediafire.com/download/ya563 ... zpt212.zip. (It's freeware btw and very good too :wink: )
For now I have reverted to XnView 2.12 because of this. Hopefully this can be addressed in a forthcoming XnView version. :)
Thanks.
captaincavern wrote:Hello, since version 2.13, opening an image with AzPainter2 from an XnView toolbar button doesn't work anymore. This program only supports opening an image at once and fails to open anyhing if multiple files are sent to it.
But if you select only one file, it works??
drugo
Post by drugo »
captaincavern wrote:Hello, since version 2.13, opening an image with AzPainter2 from an XnView toolbar button doesn't work anymore. This program only supports opening an image at once and fails to open anyhing if multiple files are sent to it. It seems the 2.13 fix messes with it even though I don't try to open multiple images in it from xnView. It's japanese software but there is an english translated version here: http://www.mediafire.com/download/ya563 ... zpt212.zip. (It's freeware btw and very good too :wink: )
Thanks.
hi
can you click on the program and drag the photo?
captaincavern
No it doesn't which is the point of my post. Even though I send a single file to it (from toolbar button in single image view mode) it now acts as if multiples files are sent to it and doesn't open it.
captaincavern
drugo wrote: hi
Hi, I am not sure what exactly you mean here.
captaincavern
Hi, is it possible you can do something about this?
To reexplain the problem, I can't open a file anymore in AzPainter2 from an XnView View mode button since v.2.13 and since I use this software very often for most edits I remain using XnView v2.12 because of this.
Thanks.
captaincavern wrote: To reexplain the problem, I can't open a file anymore in AzPainter2 from an XnView View mode button since v.2.13 and since I use this software very often for most edits I remain using XnView v2.12 because of this.
captaincavern
This happens in View mode where there is only one file at play, I don't have custom toolbar buttons in Browser mode.
and from browser it works?
captaincavern
xnview wrote:and from browser it works?
Just tried and no it doesn't either.
