Switch tabs with keyboard.
MadMaverick9
Post by MadMaverick9 »
First of all - Thank you very much, Pierre, for developing XnViewMP.
All/Most applications that provide a tabbed interface allow the use of Ctrl-Tab/Ctr-Shift-Tab and/or Ctrl-PageDown/Ctrl-PageUp to switch tabs. And on Linux in Opera, Firefox and Pidgin this works fine for me.
I could not get this to work in XnVIewMP. I looked in "Settings -> Interface -> Shortcuts" (and other places) - no luck.
Did I miss something?
Or is this a feature that maybe you could add to XnViewMP.
Thanks for your consideration.
m.Th.
Re: Switch tabs with keyboard.
Post by m.Th. »
+1 for ctrl+tab, ctrl+shift+tab
m. Th.
