I.E. not all are converted
0.61: for Mac. Not every pictures are selectable
Oleg-Sentia
0.61 for Mac. Not every pictures inside directories are selectable when I select them as directories for batch operation.
ULK
Re: 0.61: for Mac. Not every pictures are selectable
I am using XN retro for at least 6 month on Mac OS and everything was ok but last time i tried to open a file, no file could be selected ;( ;(;(
I can't open any image ;(
Which format?Oleg-Sentia wrote:0.61 for Mac. Not every pictures inside directories are selectable when I select them as directories for batch operation.
I've updated the version on Apple StoreULK wrote:I am using XN retro for at least 6 month on Mac OS and everything was ok but last time i tried to open a file, no file could be selected ;( ;(;(
Oleg-Sentia
format and extension is jpeg (*.jpeg)xnview wrote:Which format?Oleg-Sentia wrote:0.61 for Mac. Not every pictures inside directories are selectable when I select them as directories for batch operation.
if *.jpg everything is Ok
if I select *.jpeg directly, not inside the directories, everythig is Ok
you means that you use 'add folder', and .jpeg are not added?
ULK
Waouh !Super quick update.Oleg-Sentia wrote:format and extension is jpeg (*.jpeg)xnview wrote:Which format?Oleg-Sentia wrote:0.61 for Mac. Not every pictures inside directories are selectable when I select them as directories for batch operation.
That works fine !
Thank you
Oleg-Sentia
yes it is.xnview wrote:you means that you use 'add folder', and .jpeg are not added?
Two ways with one result.
1. 'batch convert' --> 'add folder' = no file .jpeg are selected in the 'input window'
2. select folder by mouse --> 'batch convert' = no file .jpeg are selected
ok, it's fixed in next version
