Susie plugin support question
captaincavern
Post by captaincavern »
Can someone let me know if it does work or not and if it does if there is some special setting for it before it does.
I just put the spi files in the XnView plugins folder along with the XSusie.dll but it doesn't work.
I only tried the two Susie plugins for image formats I am using:
AzPainter2 :http://www.mediafire.com/download/ya563 ... zpt212.zip
Susie plugin for AzPainter2 files: http://kt.sakura.ne.jp/~timeflow/prog/IFAPD.ZIP
Edge: http://takabosoft.com/?download=edge129a.zip
Susie plugin for Edge files: http://takabosoft.com/?download=EdgeSPI100.lzh
Those two plugins work fine with japanese image viewers Massigra and PictureFan for example.
Thanks.
Re: Susie plugin support question
could you send me some examples of picture files?
captaincavern
Correction: It's only AzPainter files that don't work, turns out XnView can open Edge ones with XSusie.dll +edge.spi (I had forgotten to put the edge.spi in the plugins folder when i first tried :P )
I have uploaded an AzPainter file and the plugin here: http://www.datafilehost.com/d/fce36a79 (Make sure you uncheck "Use our download manager" before you click on the download button)
Thanks.
Xsusie.dll is no more needed. The plugin return an error for this apd file
captaincavern
It's the same for every other apd file I have, none open in XnView whereas they all open in Massigra and PictureFan using the same plugin. Do you think you can do something about it or is it a lost cause? Thanks for your time any way.
yes strange if i don't call the method to check the file header, it works...
captaincavern
Just noticed this is now working fine. Thank you for the fix!
