1.) Run XnView MP 0.61
2.) In 'view mode' go to "Capture" and do a desktop screen capture with a 5 second delay
3.) With captured image, press "Save" OR....
4.) ...Before pressing "Save" do a "Spotlight" on the picture...
5.) ..Press "Save" and see if you see a default filename..
6.) ..There is NO default filename in the save dialog
default filename = Screen-{year}-{month}-{day}_{time}
Pierre, I can send you my INI file for you to do a private test and I could make a video, thank you.
0.61 win-x86: Capture = weird default filename not used
budz45
Re: 0.61 win-x86: Capture = weird default filename not used
Bug confirmed and will be fixed. See issue Issue 177 for current status and details.
budz45
Thank you. Fixed in XnViewMP 0.64
