.FIT files : XnviewMP vs Xnview ??
Benji
Post by Benji »
would like to use MP to view/zoom/sortout batches of numerous astronomical pictures : very dark pictures (left left side of histogram).
Xnview shows the FITS files as wished, very fast, with a medium stretch. But no possibility to enlarge the thumnails as I would like, and no possibility to open a picture separately (like double click in MP), nor full-screen.
XnviewMP allows opening files separately by double click, and full-screen view. But the FITS files appear very dark, with no stretch. Obviously the FITS files are not decoded in the same way in the 2 programs ? Not possible to use it as is.
In both cases (classic and MP), gamma correction does not work.
Would it be possible to have best of both : features of MP with viewing quality of classic ?
Same pictures seen in both softs :
Ben
Re: .FIT files : XnviewMP vs Xnview ??
strange, could you send me the fits file?
Benji
Post by Benji »
Here is a link to a file
https://www.dropbox.com/s/x832q80249k6g ... 01-001.fts
hope it works...
Ben
Benji
Post by Benji »
OK, I could get xnview classic work better (reinstall and apply all file formats). I can have single files opened and full screen view working.
Not so bad, but thumbnails are much too dark now...
I have the same in the 2 versions
Benji
Post by Benji »
I now have also the same views in both versions. Impossible to recreate the same viewing as in initial post, really dont know how I did it :(
But anyway, my initial problem remains that fits files viewing is much too dark, and can't find a way to view my files easily.
Basicaly for viewing my fits files, I currently use an veeeeery old version of acdsee. It uses a fits plugin wich applies an adaptative linear stretch, which delivers comfortable view for this type of very dark files... But this old soft is veeeery slow. Wish I could find something like this in xnview.
example of thumbnails on the same directory :
https://imageshack.com/i/0w3ac8j
https://imageshack.com/i/nrqllnj
Ben
are you able to save it with this old version using this linear stretch?
Benji
Post by Benji »
Sorry not possible to save in fits format. It is only a decode plugin.
Only thing I have is this plugin properties screen : one can choose several stretching profiles, and looks like the plugin uses the cblack and cwhite values which are in the fits header.
https://imageshack.com/i/git1sgj
Sorry but i means in PNG for example
niccoc1603
Post by niccoc1603 »
It would be nice to have stretch curve applied to FITS thumbnails, they are pretty much unusable without any stretching applied
