In Viewer mode, when pressing Enter to switch to Browser mode, switches to Browser mode for a split-second and goes back to Viewer mode. However, using the Keypad Enter key or Esc key instead switches fine.
In Browser mode, when pressing the Keypad Enter button, it doesn't switch to Viewer mode. However using the main Enter key (near the letters) works fine.
Seems the main Enter key and Keypad Enter key are treated differently.
0.61 Win-x64 - Switching between Browser/Viewer by keyboard
Firestorm ZERO
Re: 0.61 Win-x64 - Switching between Browser/Viewer by keybo
I can't reproduce, ENTER & RETURN switch between View&Browser mode correctly
Firestorm ZERO
Ok. Did some more testing. I found out it only happens if Browser mode is in either "Detail" view or "Thumbnails + Details" view. Any other view (Thumbnail, Icon or List view) and both Enter+Return keys are fine.
Bug confirmed and will be fixed. See issue Issue 183 for current status and details.Firestorm ZERO wrote:Ok. Did some more testing. I found out it only happens if Browser mode is in either "Detail" view or "Thumbnails + Details" view. Any other view (Thumbnail, Icon or List view) and both Enter+Return keys are fine.
