Constant annoying crashing
speedy25
Post by speedy25 »
I opted for xnview since AcDsee became bloatware.
It works OK, but I am having a constant crashing usually the same folders. Sometimes it hangs and comes back, but usually its a crash and I get the windows popup that asks if I want to close or look for a solution. BTW- No solution ever comes back. Never for any other programs either so I think that a dumb windows problem.
Running on 2 different computers. A laptop with vista and a desktop running XP. Both behavior is the same. Image files are from canon and fuji cameras. It doesnt seem to crash with the 3-D mpo files. Always seems to be just a directory with jpg.
Updating from 1.99 to 2.13 didnt change the problem.
It has some other annoying features but I'll address them separately.
Thanks for any help you can give to fix this.
-SP
Re: Constant annoying crashing
no video files? are you able to find which file?
