In XnView you can choose to delete selected or tagged files, the corresponding ini option is SelectedShowAgain.
This option seems to be missing in XnViewMP.
The only workaround I see in the current version 0.61 is to first select tagged files (menu / assign shortcut) and then delete these selected files.
Please add an option to the delete dialog or an menu entry/shortcut "delete tagged files".
Delete tagged files
Re: Delete tagged files
Bug confirmed and will be fixed. See issue Issue 189 for current status and details.
