Poor pdf quality
Agent Fred
Poor pdf quality
Post by Agent Fred »
I scanned some documents with 200x200 dpi black & white and saved in pdf format. When I open it in xnview it looks pretty poor and also if I print it via xnview the result is unsatisfying. If I open same file in Adobe Reader it looks much better and the printout ist also better. Are there any settings to improve quality within xnview?
Regards
Fred
Re: Poor pdf quality
The default Ghostcript resolution is 72 DPI so you need to increase that to 200 DPI or whatever value you wish to use:
Tools > Options... Read/Write -- Read -- EPS/PS/AI/PDF -- DPI :
Agent Fred
That's it. Thanks a lot. Really an awesome software ...
