When I start xnviewmp (32 or 64 bit version make no difference) I am not offered the option to create a slide show (under create only "web capture", "file listing" and "video gallery" are being offered as a choice. See attached screen print.
I m running Windows 7 and have also xnview classic (2.03) installed on my system. Any help would be greatly appreciated.
Andreas
Slide Show
andreas44
Slide Show
- Forum Librarian
Re: Slide Show
Hello Andreas
The slideshow feature has yet to be implemented in MP.
Giovanni
Re: Slide Show
Is it also possible that the Slideshow feature is not yet available on the version XnViewMP
Version 0.69 x64 (Oct 8 2014) for Mac?
bug
Re: Slide Show
I can only start a slideshow if I am looking a photo in full screen mode - but then only a slideshow for the current directory.
I find no way to start a slideshow of selected directories (including subfolders).
