Thumbnails print
MaeZ
Thumbnails print
Post by MaeZ »
i suggest to let print thumbnails as thumbnails,
so one can print multiple images on one single paper.
Dreamer
Post by Dreamer »
You can use Contact Sheet, just select images in browser and go to menu - Tools > Create Contact Sheet (or just use a toolbar button).
Dreamer wrote:You can use Contact Sheet, just select images in browser and go to menu - Tools > Create Contact Sheet (or just use a toolbar button).
Right. This way printing of thumbnails is possible, but this should be considered as a workaround, not a real solution. A real solution would be:
1.) Select images in browser.
2.) Select menu "File > Print"
3.) Choose template "Thumbnails"
4.) Press "OK".
This is the way I think this should work (for all I know XnView DeLuxe exactly provides this).
