Please consider implementing drag/drop to rearrange thumbs in the Compare tab thumbstrip.
Many times the purpose of a comparison activity is to identify a sequence of images. It would be useful to build the sequence by dragging in the thumb strip while comparing images.
As a partner to this capability...
...a renaming function to sequence the filenames (by appending sequence numbers from left to right) would be very very useful. (Such a function would be good in the browser, too.)
Thanks for listening!
Request: Drag/drop to rearrange Compare thumbstrip
JohnFredC
m.Th.
Re: Request: Drag/drop to rearrange Compare thumbstrip
(emphasis mine)...a renaming function to sequence the filenames (by appending sequence numbers from left to right) would be very very useful. (Such a function would be good in the browser, too.)
What do you mean?
In browser there is already such a function. And I'm not against to "port" it in the Compare window.
m. Th.
JohnFredC
I meant a specific "make sequence" function.
If the renaming tool were available in the thumbstrip AND multiple select was also available, then that would suffice.
John
m.Th.
I don't see any serious impediment in implementation. I think that the most serious is marking (by color? shape?) the 2-4 views in a different way compared with your multi-select. Also, I see a little fuzziness in mouse management: How do I select a photo for a Compare view and how do I do a multiple select?JohnFredC wrote:I meant a specific "make sequence" function.
m. Th.
JohnFredC
Maybe an image "basket" instead of multi-select?
John
m.Th.
JohnFredC wrote:Maybe an image "basket" instead of multi-select?
Oh! Oh! Oh!
Image 'baskets'! ....Btw, do you use(d) IDImager? Or Photo Supreme?
...Or ACDSee? (ok, ACDSee has also Burn Basket and Keywords)
...Or 'Quick Collection'/'Collections' in Lightroom?
...Or 'Albums' in a dozen of other programs? (Photo Album, Thumbs Plus etc.)
...Or 'Albums' in Zoner?
I put also a request for Albums some time ago in forums: http://newsgroup.xnview.com/viewtopic.php?f=60&t=28322
Today everyone needs such a task oriented cataloging. Categories tree are content oriented cataloging.
Shall we go there to continue our discussion?
m. Th.
