Please implement file rename, file move, and file copy in Compare tabs. I frequently use Compare very seriously, not just for a casual glance to see which image is preferred... and those functions would be usefully integrated with the Compare workflow.
Certainly would save many steps....
Request: File operations in Compare
JohnFredC
m.Th.
Re: Request: File operations in Compare
JohnFredC wrote:Please implement file rename, file move, and file copy in Compare tabs. I frequently use Compare very seriously, not just for a casual glance to see which image is preferred... and those functions would be usefully integrated with the Compare workflow.
Copy, Move & Delete are already there. Look on the toolbar.
m. Th.
JohnFredC
Now that's embarrassing. I'm so used to the context menu...
So I guess what I'm really asking is for some form of extended select in Compare.
Edit: but rename is still missing...
John
