Compare images: return to Browser view
cicciobello
Post by cicciobello »
In Compare images, how do I return to Browser view?
- Esc not working
- Alt+F4 or ^F4 close XnViewMP
- "Close" button close program when closing last open image
Fraenzken
Re: Compare images: return to Browser view
Post by Fraenzken »
As far as I know, you can just close the Compare-Tab by clicking on the "x" in the upper right corner.
That said, the possibility to close it by pressing Esc would be great :D
Apart from that: Thanks for this great program!
cicciobello
[quote="Fraenzken"]As far as I know, you can just close the Compare-Tab by clicking on the "x" in the upper right corner.
Click on the "x" in upper right corner _close_ XnViewMP. There is no way to return in Browser mode.
I have set XnViewMP to switch from Browser mode and Fullscreen mode and viceversa. View mode
with menu and title bar is practically disabled.
[BUG?] Sometimes in Browser mode, selecting 2 files and Shift+C for Compare resulting in immediately
program exit.
m.Th.
Post by m.Th. »
cicciobello wrote:
Fraenzken wrote:As far as I know, you can just close the Compare-Tab by clicking on the "x" in the upper right corner.
program exit.
You must click in the upper right corner of the tab. See the highlighted area:
m. Th.
cicciobello
m.Th. wrote:You must click in the upper right corner of the tab.
Uhm... I have _disabled_ the tabs to use all screen space.
I have disabled also the tab close button, to prevent accidentally closing if using tabs.
Anyway, with ^W I can close "Compare images" and return to Browser view. Thank you.
Bug confirmed and will be fixed. See Issue 200 for current status and details.
