Description of the database and search functionality
ErikBachmann
Post by ErikBachmann »
I'm testing the XnViewMP search functionality since the search function in XnView is sloooow on large amounts of files (>10K) - on Windows at least.
When I open the Search window in XnViewMP (v0.64) and check the "Use database" check box - I cannot find anything in the database at all. No IPTC, no rating.
I've taken a look at Tools / Settings / Database:
  • Added "Base path of your pictures"
  • Ran the "Rebuild thumbnails"
  • Even included the pictures path in the "Excluded/included" tab
Still nothing found in database.
In the "View" menu I've tried the "Rebuild thumbnails" and "Update database from files" - but still ...
Could anyone please describe:
  • How to update the database with IPTC and other meta data?
  • Where can I find the IPTC data in the database (for verification or export) ?
Best regards
{ö} Erik Bachmann
Best regards
{ö} Erik Bachmann
JohnFredC
Re: Description of the database and search functionality
Post by JohnFredC »
0.64 searching "use database" fails with every example I have tried.
By "fail" I mean nothing happens: the "Searching" popup never populates.
Disabling "use database" gives results instantly.
John
What do you have in Conditions??
JohnFredC
Post by JohnFredC »
I tried several different criteria. Here is a screen shot of a file size search.
MP will remain in this condition until I cancel the search.
Disabling "Use database" causes MP to display the proper results of the search.
John
oops66
Post by oops66 »
JohnFredC wrote:0.64 searching "use database" fails with every example I have tried.
FI: Same problem here with "search IPTC keywords" and with settings...
Case sensitive = off
Use database = on
Recurse through subfolders = on
Match Any of the following conditions = on
ErikBachmann
Should the database search search through the Meta blob in table Images in XnView.db?? (And how do you interpret the Meta blob) ?
Or is search based on the field Label in table Tags?
Tags seems to contain some entries from IPTC keywords - but no other entries from IPTC or EXIF.
Best regards
{ö} Erik Bachmann
m.Th.
Post by m.Th. »
Old bug. From 0.5x IIRC.
m. Th.
m.Th.
Post by m.Th. »
The true solution is described here: http://newsgroup.xnview.com/viewtopic.php?f=60&t=28345
m. Th.
I see that you have *.*, please try by removing it
JohnFredC
Post by JohnFredC »
xnview wrote:I see that you have *.*, please try by removing it
Well, that solved the problem, though in a counter-intuitive fashion, IMO.
John
m.Th.
Post by m.Th. »
Also I think that this is counter-intuitive.
Also, how can one search for the files which have eg. FileSize > 25 AND filename = '*.jpg'?
Either you'll do it through SQL (which is recommended, being much faster), either by plain-vanilla scanning is quite simple to do it.
PS: Solution available upon request, as always. :)
m. Th.
Yes, it seems that it's a problem with sqlite :(
m.Th.
Post by m.Th. »
xnview wrote:Yes, it seems that it's a problem with sqlite :(
See your PM :)
m. Th.
Bug confirmed and will be fixed. See issue 215 for current status and details.
