Here are few easy steps to kill / destroy your Info Pane:
1. Make sure that you have the Free Layout mode on. It is done from View | Layout | Free...
2. Undock your Info Pane. It is done by dragging from the caption bar. A floating window appears with the Info Pane in it and a Red Close button in the right-upper corner.
3. Close your Info Pane. It is done by clicking on the Red Close button in the right-upper corner of the floating window.
Enjoy... ...NOT!
Now the Info Pane is lost. There is NO normal way to bring it back.
Suggestion/Fix: Please add a Show button in View | Info Pane... like the one from View | Tree Pane...
For the ones who are desperate here's a workaround: Open the Full Screen mode (F11 by default) and close it back. Then go to View | Layout | Layout 1 to show it again.
How to kill / destroy your Info Pane
m.Th.
m. Th.
orbspider
Re: How to kill / destroy your Info Pane
Hi m.Th,
you can add "info pane (menu)" selection button to the toolbar and then just click on it to show/hide the info bar!! easy.
Build Debian http://dquinton.github.io/debian-install/
m.Th.
orbspider wrote:Hi m.Th,
+1 for the easiness!
-1 for not having a 'Show' menu item somewhere...
m. Th.
On Dock title, you have a popup menu with all pane, you can change visibility here
