Can i create custom toolbar buttons?
Litr
Post by Litr »
In the toolbar settings, you can create a blank button and enter a command. Is there a list of commands for XnViewMP?
For example, I want to make a four buttons (not menus): "Thubmnail + labels", "Details" and "Sort by Date", "Sort by Name"...
Is that possible? :?:
Re: Can i create custom toolbar buttons?
all available command are shown in the list, these entries are not available in command
m.Th.
Post by m.Th. »
Litr wrote:In the toolbar settings, you can create a blank button and enter a command. Is there a list of commands for XnViewMP?
For Sort you can do it: Open the Sort menu from the small File Toolbar above the Thumbs pane and choose 'Show Header'. Right Click on the Header which appears and you can choose which buttons to be shown.
For the other thing, why do you want such a quick switch? Perhaps the info pane will serve you better?
m. Th.
