The File conflict dialog appears when it shouldn't.
Steps:
1. Select a thumbnail and press F2 to enter in Filename Edit mode
2. Click on another thumbnail
Expected: The Filename Edit mode should be canceled and the new thumbnail should be selected
Actual: The Filename Conflict (the Replace | With...) dialog appears
Too much Rename
m.Th.
Too much Rename
m. Th.
CreativeWorld
Re: Too much Rename
This problem was probably introduced when this was fixed:
Missing message if a file can't get renamed
http://newsgroup.xnview.com/viewtopic.php?f=60&t=28458
orbspider
Re: Too much Rename
it's actually logical, although it may not be desired by any one, and it may surprise users...
when a file is in name edit state, and you click on another file, you are asked if you want to change the file name to the file you clicked on secondly -and if to exact same name it will overwrite, hence the confirm or "copy of xyz" dialogue
Build Debian http://dquinton.github.io/debian-install/
m.Th.
Re: Too much Rename
The computer logic is very different sometimes from the human logic.
m. Th.
Re: Too much Rename
Bug confirmed and will be fixed. See issue Issue 244 for current status and details.
