I miss the feature to have possibility to mark photos (for following actions) by pressing space while viewing them in fullscreen-mode. It would be good also to have some symbol in a corner, that photo is marked.
Thank you
Dmitry
Mark photos in fullscreen mode
m.Th.
Re: Mark photos in fullscreen mode
The best way would be to put the same keyboard processing engine from the thumbs pane. In this way we will have everything there, automagically: tagging, rating, coloring & keywording.mitya wrote:Hello,
Thank you
Dmitry
Also I support the idea to have tag/rate/color optionally showing somewhere. Perhaps Pierre can use the same drawing code from the left-top area of the thumbnail.
m. Th.
oops66
Hello,mitya wrote:Hello,
Thank you
Dmitry
The "Ctrl+ t" shortcut works here in fullscreen to tag files.
.... (Ctrl + t) for XnViewMP
Tag(ctrl+t): {Tag status} XnViewMP Linux amd64 -> Debian - MX - antiX
m.Th.
Sorry, but...The "Ctrl+ t" shortcut works here in fullscreen to tag files.
...How it is supposed to find this combination?...
As I said, I would rather use in the Full Screen mode the same keyboard engine from Browser pane and if the key pressed doesn't match with any shortcut known in that keyboard procedure only then I'll call the custom Full Screen keyboard code which I would keep to bare minimum in order to avoid code duplication, user confusion, frustration etc.
m. Th.
mitya
Thank you very much! I changed hotkey to "space" and set info to display {Tag status}.
oops66
Hello m.Th,m.Th. wrote:Sorry, but...The "Ctrl+ t" shortcut works here in fullscreen to tag files.
Into the settings\interface\shortcuts, the "Current tag" for View mode (or fullscreen mode) is= Ctrl+t
Hello,mitya wrote:Thank you very much! I changed hotkey to "space" and set info to display {Tag status}.
You 're welcome
neunharpyi3
Hi XnView Team,
is there any possibility to make the Tags (Number 1,2,3,4,5 for Rating) without the Ctrl in Fullscreen Mode?
