Why is there this problem, which in the version 0.64
yilusheji
Post by yilusheji »
Why is there this problem, which in the version 0.64,In the case of software, the window closes maximized, and then turn on the emergence of this situation,I had a lot of reaction times, which I hope the author can change in the next version
Re: Why is there this problem, which in the version 0.64
Sorry but i don't understand, you have a problem when you quit XnViewMP with maximized state? Not in previous version??
rmtk
Post by rmtk »
yilusheji
Post by yilusheji »
xnview wrote:Sorry but i don't understand, you have a problem when you quit XnViewMP with maximized state? Not in previous version??
it could be windows7 issue, but when i restore MP from maximized mode it looks like this, so i need to re-size MP window again. besides TreePane became very narrow, so have to adjust it as well. i happens couple times a day, a bit annoying..
please look it it could be fixed
yilusheji
Post by yilusheji »
It is an old bug: viewtopic.php?f=62&t=26172
but it was fixed!
GeorgD
Post by GeorgD »
xnview wrote:but it was fixed!
Sorry to say, Pierre, but window size is "forgotten" also here (v0.64 on Win 7 64bit).
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
You start XnViewMP, maximize it, quit, and when you restart it's no more maximized??
GeorgD
Small window size / was: Re: Why is there this problem, whic
Post by GeorgD »
xnview wrote:You start XnViewMP, maximize it, quit, and when you restart it's no more maximized??
On the contrary, it is. My sequence: I start XnViewMP, resize it (e.g. to 3/4 of the screen), maximize it, close it, restart it (it is maximized), un-maximize it and then it's in most cases as big as I made it last time, but sometimes it's so small as shown in the screenshots. I did not yet find any pattern when it's big/small; I've the impression it has to do with changed monitor resolution as it happend the last times after I (dis)connected my Laptop to an external monitor. As it's seldom and very easy to fix (just resize the window and move the vertical separator (Layout3) because left part with preview is too narrow), this issue is not so important for me :)
Re: Small window size / was: Re: Why is there this problem,
i can't reproduce, but you have not the bug every time, right??
GeorgD
Post by GeorgD »
xnview wrote:i can't reproduce, but you have not the bug every time, right??
Right, I also cannot reproduce it reliably.
