From 1 to 24 bit... magically?
cicciobello
Post by cicciobello »
Please test this: TIFF uncompressed 1 BPP, batch convert, add watermark with
LZW TIFF 1 BPP, format "As original". Result: uncompressed TIFF 24 BPP.
Re: From 1 to 24 bit... magically?
add watermark convert image in 24bits...
cicciobello
xnview wrote:add watermark convert image in 24bits...
Well, so it's not a bug.
I insert an action to (re)convert in 1 BPP.
Operations on grayscale and bi-level images using image editing software often seem to change the bit depth to 24bpp, so it is always worth monitoring that in the status bar!
