Beware at 'Create folder' dialogs in Move workflows. If you answer 'No' you will lose a photo!
Steps:
1. Select several photos.
2. Press Alt+M (the shortcut for 'Move To')
3. In the Edit Field write down a folder name which doesn't exist. Press Enter.
4. The "Create Folder" dialog appears, asking if you want to create the new folder. Answer "No".
Expected:
The process should stop here.
Actual:
A new dialog appears saying that it was "a problem with the destination". If the user chose 'Skip All', the first photo will be deleted!
How to accidentaly delete your photo (dangerous bug)
m.Th.
m. Th.
Re: How to accidentaly delete your photo (dangerous bug)
Bug confirmed and will be fixed. See issue Issue 245 for current status and details.
