There are errors in 'Selected Files / Tagged files / Cancel' workflow. Basically it appears too much.
Steps:
1. Go to a folder and tag some files. Select others.
2. Choose 'Move files' (Alt+M)
3. A dialog appears saying "What do you want to use: {Selected Files} {Tagged Files} {Cancel}"
If one press 'Cancel'
Expected: The workflow will stop.
Actual: The Move dialog appears.
If the user press 'Selected Files', then the Move dialog appears which is correct but let's continue
4. Entering the destination path and press Enter.
Expected: The move operation should start
Actual: The {Selected Files} {Tagged Files} {Cancel} appears again which is wrong.
Problems with 'Selected files / Tagged files / Cancel'
m.Th.
m. Th.
Re: Problems with 'Selected files / Tagged files / Cancel'
Bug confirmed and will be fixed. See issue Issue 243 for current status and details.
