Is there anyway to get MP to show SKP thumbs???
It used to. This is the reason I have it. XNview does but that doesn't show 3DS.
MP does not show ANY SKP, tried everything.
Would show some before update but new. Now since I tried rebuilding thumbs Noda!
Sketchup SKP Thumbs
m.Th.
Re: Sketchup SKP Thumbs
Here is the Python code to read the embedded thumbnail:
#! /usr/bin/python
# Use this script as thumbnailer with Sketchup in Wine @ Linux:
# 1. Save the script in /usr/bin
# (for example open the terminal and type: gksudo nautilus /usr/bin)
# 2. Register this thumbnailer in the Gnome configuration using these commands in the terminal:
# gconftool-2 -s /desktop/gnome/thumbnailers/application@x-wine-extension-skp/enable --type=bool true
# gconftool-2 -s /desktop/gnome/thumbnailers/application@x-wine-extension-skp/command --type=string "python /usr/bin/skp-thumbnailer.py %i %o"
import sys
import struct
import os
counter=0
def pngcopy(infile, outfile):
# copy header
header = infile.read(8)
# if header != "\211PNG\r\n\032\n":
# raise IOError("not a valid PNG file")
outfile.write(header)
print header
# copy chunks, until IEND
global counter
while 1:
chunk = infile.read(8)
size, cid = struct.unpack("!l4s", chunk)
print counter,chunk
outfile.write(chunk)
outfile.write(infile.read(size))
outfile.write(infile.read(4)) # checksum
counter+=1
if cid == "IEND":
break
infile = open(sys.argv[1], "rb")
infile.seek(0x76d)
outfile = open(sys.argv[2], "wb")
outfile.close()
# remove the thumbnail if it is empty (ie. because of not working png exporter in Sketchup in Wine)
if counter<=5:
os.remove(sys.argv[2])
infile.close()
m. Th.
I can't reproduce, SKP have thumbnails
