Animated Image To clipboard
sartaros
Post by sartaros »
Hello!
I do next 2 actions with Windows release of Xnview. Copy Xnview Window with animated Image to clipboard (ctrl+a,ctrl+c).Insert clipboard (ctrl+shift+v).
- The result is disappearance of animation. There is analog of Embarcadero CF_GIF clipboard format?
means message
Error: This picture cannot be written using this format (D:\Clipboard.gif)
Please, clarify this results.
Best regards
Alex
DOS386
Re: Animated Image To clipboard
Post by DOS386 »
Where? macrosoft library
Clipboard is just always 24 bpp static image without any fileformat or metadata. WOW.
Try "-colors 256" (but forget animation).
Note that copying GIF animation onto another GIF animation with or without the clipboard would be extremely difficult. I dobt that XN ever will support this.
