iptc/exif gps coordinates??
orbspider
Post by orbspider »
Man I need this feature and I just can't see it (and I'm pretty sure because its not there)
1. Open IPTC/Exif dialogue and on Source tab show the GPS coordinates - and be able to enter them if none are attached, edit them if deemed off.
Even better if multiple files can be set with same geo-coordinates in one go (sometimes quite necessary). At the moment it would be one-by-one cursing through the images that were selected in browser mode, pasting the Lat/Long coordinates for each one, then save all.
2. What about a button by each field in IPTC/Exif dialogue, that when pressed applies the data to the same field of all selected files??? (This may be only useful for credits, status and source tab fields.)
or a button at bottom of window "apply all fields to selected files" (which doesn't save to file but duplicates the info to all the selected files' fields)
works just for fields of current tab
this might save some one a load of time as wouldn't need to enter same info multiple times
m.Th.
Re: iptc/exif gps coordinates??
Post by m.Th. »
Batch Editing implies a rethink for (at least) the GUI design of the form. It need either to be a pane in the main form either to have a strip of thumbs to support multi-selection.
The code to batch assign would not be very difficult to do IMHO. But the form must be designed properly. If someone is interested, raise the hand.
m. Th.
