Nouvelle bordure
Zen
Nouvelle bordure
Post by Zen »
Could you please add a border (and a new option) to obtain the following result?
Thanks
Bonsoir,
Pourriez-vous ajouter une bordure (et éventuellement un traitement) pour obtenir le résultat suivant ?
Merci
Re: Nouvelle bordure
XnRetro wrote:
XnRetro allows you to create stunning images with vintage or instant effect on your Desktop.
  • 20 color effects
  • 15 light effects such as bokeh, leak
  • 28 frame borders
  • Adjustement like contrast, gamma, saturation, ...
  • Vignetting
  • Noise
  • Save or share the result
oops66
Post by oops66 »
Maybe it's the time to implement the 8BF files Adobe Plugins Filters into XnViewMP too ??? ... for more creativity ;-)
http://newsgroup.xnview.com/viewtopic.php?f=61&t=13031
Edit: "pour les cadres" (borders):
http://www.photofiltre-studio.com/forum ... =3&t=17403
http://www.archive-host.com/compteur.ph ... cadres.pdf
ENCADREMENTS
AAA filters
ALF'S border
FU-andrews filters-1-boxed
bordure mania
FU-AFS-sqborder 1/2/3
FU-buttons and frames
FU-edges-round-tous
FU-edges-square-tous
FU-encadrement
FU-filter factory-C/G/L/M/P/R
FU-frames—(tous)
FU-harry's-power grads
FU-VM-toolbox-metal frame
photo swizzle
... So, in your case maybe the filter: "Control Noise & Width" ?
http://punkinstuff.tripod.com/alfs/alfs1.html
oops66 wrote:Maybe it's the time to implement the 8BF files Adobe Plugins Filters into XnViewMP too ??? ... for more creativity ;-)
I totally forgot about the Photoshop-compatible filters, oops66 :D
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=109390#p109390]Re: Adobe plugins[/url]) wrote:View mode: Image » Adobe Photoshop Plugin... » Configure... » Add...
oops66
Post by oops66 »
XnTriq wrote:...I totally forgot about the Photoshop-compatible filters, oops66 :D ...
Hello XnTriq, FI: here it is a good summary too (in pdf)
...Summary added here: ;-)
http://newsgroup.xnview.com/viewtopic.p ... 138#p72138
... Strange, I do not have this menu: "Adobe Photoshop Plugin", why ??? (into the view mode) into XnViewMP0.64 Linux version (64 bits version) ... even if a bug exist and only 32bits seems to be compatible at the moment ... so I continue to use in rares cases the XnView 2.X classic version with Wine for 8bf filters ... or GIMP ;-)
Thanks!
oops66 wrote:Strange, I do not have this menu: "Adobe Photoshop Plugin", why ???
Perhaps the feature has only been implemeted for Windows :?
Does the keyboard shortcut (Ctrl+G) work under Linux?
oops66
Post by oops66 »
XnTriq wrote:...Perhaps the feature has only been implemeted for Windows :?
Hello XnTriq,
... Your are right, it's not the same menu (into the View mode \ Image\ ...)
And I do not have the shortcut Ctrl+G
My "IMAGE" menu is ( with XnViewMP 0.64 Linux X64 - Ubuntu 12.04 LTS - X64 ):
Count colors used
Change color depth...
Map >
Adjust >
Rotate >
Mirror >
Swap >
Extract channel >
Resize... ShÎft+S
Canvas resize... Shift+C
Spotlight...
Filter...
User filter...
And the "User filter" ...
... So, is the "Adobe Photoshop Plugin" is now only for the MP Windows version ?
oops66 wrote: ... So, is the "Adobe Photoshop Plugin" is now only for the MP Windows version ?
yes the windows 32bits version
oops66
Post by oops66 »
... Thank you for the information Pierre.
