Auto-Refresh After Rename
DaveN
Post by DaveN »
How can I make XnView automatically refresh or sort my thumbnails after I rename a file? I am renaming files 01, 02, 03,...... and want them automatically placed in order after a rename without me having to 'refresh' with CTRL/r.
Re: Auto-Refresh After Rename
Is Auto refresh (Tools » Options... » Browser » Browser) activated?
DaveN
Post by DaveN »
Yes it is.
It seems I had an incorrect understanding of the Auto refresh setting :?
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=5576#p5576]Re: Reordering on filename change[/url]) wrote:
helmut wrote:Before continuing discussion whether this is a bug or feature, we should know exactly what this option "Auto refresh" was intended for and what it does. Pierre?
Auto refresh is used when external copy/move occurs. For example, you copy a file in the windows explorer, and the destination folder is the folder opened in XnView's browser.
currently no way, 'auto refresh' is when files are changed outside...
