Export IPTC
lewko2
Export IPTC
Hello!I have a question: what does it mean and causes the function to Export IPTC and EXF and where is exported?To make it easier to find photos I built your categories and each assigned a photos. Congratulations! in your program, it works when searching for photos. What will happen in the event of failure of the Windows and I'm going to have to reinstall your program. If your previous search data regain? thank you in advance for your reply.
Silversleeves
Re: Export IPTC
Nobody has yet had Pierre answer the question of how and what format or syntax his text IPTC and EXIF exports are in. I suspect they're ExifTool-oriented. Don't expect more than this for an answer. I've been using XnView regularly since 2007, and I still don't know if it will import what it exports, if that's what you mean by "regain."lewko2 wrote:Hello!I have a question: what does it mean and causes the function to Export IPTC and EXF and where is exported?To make it easier to find photos I built your categories and each assigned a photos. Congratulations! in your program, it works when searching for photos. What will happen in the event of failure of the Windows and I'm going to have to reinstall your program. If your previous search data regain? thank you in advance for your reply.
BZT
