Show images from a year
lian
Post by lian »
Is there a solution to filter all files from one precise year ? I did find...
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: Show images from a year
not yet
lian
Post by lian »
OK, thank you - sob sob...
oops66
Post by oops66 »
... But a workaround is possible ... you can select the "root directory" of your jpg images files then ... "show all files (recursive)" ... (can take some time) ... then "sort by "exif date" or "date" ... then TAG the selected year ... then filter by "tagged files" . ;-)
lian
Post by lian »
Not so bad idea. I never use the mark thing. It could be interesting to use for me.
